I’ve pretty much wasted my entire weekend fiddling with a wireless link between our offices (either side of a public road). The problem was finally found in another thread (http://forum.mikrotik.com/t/r52hn-impossible-to-use-400-mbps/55516/1).
2 x RB433AH
2 x R52Hn
2 x 30 inch Dual Polarised 5.4GHz Parabolic Dish antennae
I climbed up and down, aligned and re-aligned the dishes, changed cards, pig tails, cables and was contemplating getting alternative (even bigger) dishes on Monday, until I read that the signal strength should not be greater than -60dBm (mine was about -10dBm).
The link is only about 50 meters apart and the problem quite simply, as it turns out, that I was blasting the other side with an over amplified signal (amplified by the receptor having a dish too big for the distance).
I hope this helps others, our link is finally running at 300Mbps providing true TCP transfer rates of the maximum the 100Mbps ethernet port can provide… ![]()
set wlan1 tx-power-mode=all-rates-fixed tx-power=0
For 802.11n:
set wlan1 ht-guard-interval=any ht-basic-mcs=mcs-0 ht-supported-mcs=mcs-0,mcs-7,mcs-15
set wlan1 ht-txchains=0,1 ht-rxchains=0,1
NB: Setting MCS doesn’t appear to have any affect when using RouterOS 5.15, the units still slowly climb all the way through all intermediary link speeds before settling on 300Mbps.
NB: Monitoring the WiFi link, after changing settings, will always show a speed of 6.5Mbps. This will only start to climb once the link has traffic to transfer (unlike 802.11a/b/g). This may not be a problem on a bridge link, but a routed link would only see traffic when sent to it. Not sure if this is a bug or simply a from of power saving.
The stats:
status: connected-to-ess
band: 5ghz-n
frequency: 5180MHz
wireless-protocol: nv2
tx-rate: 300.0Mbps
rx-rate: 300.0Mbps
ssid: Syrex_7avenue
bssid: 00:0C:42:6C:BC:A5
radio-name: 27_7
signal-strength: -45dBm
signal-strength-ch0: -47dBm
signal-strength-ch1: -50dBm
tx-signal-strength: -48dBm
tx-signal-strength-ch0: -49dBm
tx-signal-strength-ch1: -52dBm
noise-floor: -115dBm
signal-to-noise: 70dB
tx-ccq: 100%
rx-ccq: 99%
authenticated-clients: 1
current-distance: 1
wds-link: no
bridge: no
routeros-version: 5.15
