802.11n bandwidth from pc to pc
I have configured 2 routerboard 433ah with r52n in Bridge via MPLS.
Now from Tool / bandwidth tests I get about 210 Mbps in UDP send. But why only 65 Mbps in TCP (Send)?
and even if I place the same tests from pc1 to pc2 where:
pc1 —> 433ah with r52n ----- Bridge (MPLS )------ 433ah with r52n ----> PC2
I get much lower:
80 Mbps (UDP whereas fast ethernet connection between the PC and the 433 is almost ok)
24 Mbps on TCP (SEND )!!!
i see that cpu on pc goes at 100%.
But why if i connect pc to pc with cross cable (fast ethernet) i can see about 78 Mbps TCP before cpu goes to 100%.
So:
rb1—rb2 i have 80 Mbps TCP send (after CPU on rb goes at 100%)
pc1—rb1—rb2—pc2 i have only 24 Mbps (after CPU on PC goes to 100%)
