802.11n
Hi all
I have to deploy a WLAN for a scool whitch need to download video heavy files (up to 7GO) from a local server.
I think that MIMO technology (802.11n) can provide the right solution for this case. I found a Mini-PCI module based on atheros XSPAN technologie whitch can provide up to 300Mbps BW.
But i don’t know if Mikrotik OS support this technology???
Mikrotik isn’t supported this mini-pci card.
you are not going to get those listed speeds with anything..
what is your goal here? a full wifi network, or some kind of wireless point to point for sending big files?
yes the goal is a full wireless network.
Of corse there will be some APs plugged in a central switch.
there is this Mini-PCI module: http://www.unex.com.tw/web2/english/product/detail_1.asp?c1=WLAN+Module+Solution&c2=Mini-PCI+WiFi+module&c3=802.11n+b%2Fg+mini-PCI&c4=DNMA-82
witch can provid up to 300Mbps with 3 antenna in using SST technology from Atheros.
The question is: is Mikrotik support 802.11n or not??
if not what is the alternatif for this case??
at the USA MUM (right now) you can see a 802.11n demo
does this mean that beta9 supports this card ? I see pic from mum that shows a routerboard with the triple play card in it. COOL.
Sam
honestly mt, where are there more customers? here or MUM??
Please talk about your new technologies that EVERYONE IS ASKING ABOUT:
New Routerboards
802.11n
ect…
what do you want me to say? please go to the routerboard section of the forum and you will see everything there is to see regarding this topic.
USA MUM has concluded. But on the wiki there is no presentation related to 802.11n. Are there any information about the 802.11n demo somewhere?
Best regards.
please ask me, what do you like to know?
Thanks for the reply.
I’d like to know if we can take advantage of this support of 802.11n on outdoor sites. For example, I think the most extended use of mikrotik routerboards and RouterOS is for outdoor aplications, point to point, point to multipoint and directional CPE. But on those instalations only one antenna is used ( 2 if nstreme2).
So, would mikrotik make a RIC and APs supporting n standard? would it be posible to make a PtP link with a pair or 3 pairs of antennas to get more bandwidth?
To resume, I’m interested to know if our routerboards could be provided with 802.11n cards or replaced with new routerboards when support will be included and benefit from the new capabilities.
Best regards.
rb1000+n minipci card? :sunglasses:
http://www.mikrotik.com.cn/product/newRB.htm
of course, why did you think we demoed it then? we will make such products
RB1000 doesn’t have a miniPCI slot.
why rb1000 dont have minipci??? it would be very very “strong” board.without it and without posibility to connect daughtboard from rb500 series it is only strong wired router.for this i think we can use pc hardware.its cheaper and stronger…
it’s for a rackmount. why do you need an antenna in the server room? if you need similar power with wireless, you should be looking at RB600 and RB800
no, it’s not :wink:
ok.now I have some questions: what is REAL troughtput have rb333 and rb600 series? can we do on these boards dual nstreme links with these boards? and general:price…
more information will be released a little later.
yes, you will be able to do dual nstreme with no problem.
about ethernet thoughput - the only thing that is limiting the maximum speed of RB333 is the ethernet port limitation (100mbit). you can do 300 mbit (3 ports) throughput with no problem. it’s a lot faster than RB532 and it will not be expensive.
Congrats with new Routerboards.
It lokks realy promising.
