802.11N
Is it possible to use this card: http://www.unex.com.tw/product/dnma-81
based on atheros 802.11N with mikrotik 2.9.49…?
I know that linux drivers are available but linux don’t have NSTREME, especially dual :slight_smile: :slight_smile:
802.11n is not supported by RouterOS yet, but we are working on it.
…which driver used Uldis at MUM demonstration ???
Cuccio
the one we are still working on …
:unamused:
bring it on!
This is the Great News!
Can I take this opportunity to ask you about wimax technology, do you work to support it, maybe, or you wait atheros to release minipci card based on this technology?
Also, will dual nstreme be possible with two 802.11N minipci cards ?
bokili,
your question is somehow stupid. How do you think you will use 802.11n with 3tx3rx setup and dual nstreme? You have to put 6 antennas just for one link or what?
I do not agree with you.. You have antennas with dual polarisation so you can use 3 antennas instead of 6…
Hi Normis,
Can you estimate a release date? It will be available with OS 2.9.x ? It is the only solution I know for deauthentication attacks… :frowning:
Thanks!
all new features are for v3 only. this is what makes 2.9 stable. if we start adding stuff to it, it will be exactly the same as a beta.
Still no 802.11N support in v3 ???
Not yet.
is there support for 802.11n yet?
I will never cease to be amazed how someone can ask a question with the answer being directly above them.
And the million dollar answer is: No, not yet.
