All good, I’m currently waiting for my local supplier to get in the mikrotik cards so I can test more, glad to see that the information I’ve collected so far is correct and useful
Are you guys collecting supout.rif’s for devices running with 802.11n? If not currently, do you want any? Or only if we see any problems.
Either way I’ve noticed a couple of issues:
The signal strength reporting for the HT speed rates fluctuates wildly in winbox, this may be a problem with my setup but as noted I’ll check further when I get my R52N’s
The signal reading are combined ones. In future we will improve the signal readings (maybe by adding signal for each chain). If you want to align the antennas, then you can do that by aligning each individual chain.
Does each chain (or antenna port) using .11n use a seperate 20Mhz channel or do they all share the same 20Mhz and transmit at the same time and recieve at the same time? I’ve not found any good documentation to explain that.
Please upgrade to v4.0beta3 and go to the sysltem license using winbox and update the license, it will give you a key with the correct “upgradable till”
currently it doesn’t support Nstreme, we will try to add that later.
What did you mean about 40mhz channel seperation? You ment turbo mode (40mhz channel)? N card doesn’t support that, but it can use an extension channel (another 20mhz channel) above or below the center freqeuncy.
Thanks,
Yes, I will made test x86 pc based system(Gbit ethernet) with two n-radios and bonding in each side, also I will put two dual polarization antennas per each side.
