802.1q over EoIP
Hi.
Does MT support transparent bridging of .1q tagged frames?
i.e.
MT1 eth1 connected to one end (site1)
MT2 eth1 connected to other end (site2)
There is an EoIP tunnel between MT1 and MT2, brigded with eth1 on each side.
The point is to provide a “virtual wire” between two sites (which passes tagged framed unchanged).
Will it work or do I have to create a bunch of vlan interfaces and bridge them separately?
It will work.
