Dear Board,
I don’t understand the following behaviour, maybe one of you can give me a hint?
I configured a VM with Freeradius and advice some Mikrotik Routerboards to authenticate the WiFi connections against the Radius server. Everything works fine, except one strange thing:
- A Windows 7 notebooks try to connect to the SSID
- In my Routerboard > Wireless > Registration I can see the client
- In the RouterOS Log I see an entry like: xx:xx:xx:xx:xx:xx@myssid: connected
- A popup occurs in Windows 7 and asks for the user credentials
- After 8-10 seconds I see in my RouterOS Log: xx:xx:xx:xx:xx:xx@ disconnected, 802.1x authentication timeout
- If I now put in the credentials, I got an error message from Windows 7, which seems to be very logical
To sum this behaviour up:
I really have to hurry up, because if I’m to slow (<8-10 seconds) I will get the same window for the credentials again and again and again until I’m fast enough. I checked with a Linux OS and there the timeout value seems to be much higher.
Where is this timeout value defined? Is there a possibility to increase this timeout in RouterOS or Windows?
Thanks!!!
