802.3ad bonding balances traffic improperly
In the attached file you can see the problem - balancing simply do not work(bonding1 contains ether1 and ether2). However, if i enable torch on ether1 or ether2 - everything works fine(traffic distributes almost 50/50 on both ethernet interfaces) until i stop it.
Device: CCR1036-8G-2S+
Router OS version: 6.37.1
I sent supout.rif using support form 3 days ago, still no answer though.
Up.
Up.
