Dear Sir,
Can any one tell me if Mikrotik support frequency 865-867 which newly opened for India?
thanks,
Dear Sir,
thanks,
3MHz bandwidth only? Too few for WiFi.
This band is normally used for LoRa (very low rate communication for low-power “IoT” devices).
It is not a market in which MikroTik is currently active.
Maybe it will come? As a module for RouterBoards for example.
"Thanks.. Is there any other brand access point having this band??
According to information in internet, 865-867 Mhz band in India is not for wireless networks, it is for RFID tags. So, you should look for other kind of devices, not routers and APs
