900mhz 9hpn link 1.32mile.. bad quality.. good signal? What gives?
I have a LOS with some trees (one row) 1.32 mile link with a pair of 9hpn radios. 14 dbi gain antennas on both side.
The radio says the noise floor is -110dBm.
I am using 5 mhz channel and have tried 10 and 20 as well.
Remote side.
status: connected-to-ess
channel: 907/5/g
wireless-protocol: nv2
tx-rate: 9Mbps
rx-rate: 6Mbps
ssid: xxxxxx-1
bssid: D4:CA:6D:0D:XX:XX
radio-name: 9hpn-orng-1
signal-strength: -68dBm
signal-strength-ch0: -68dBm
tx-signal-strength: -69dBm
tx-signal-strength-ch0: -69dBm
noise-floor: -112dBm
signal-to-noise: 44dB
tx-ccq: 59%
rx-ccq: 28%
authenticated-clients: 1
current-distance: 4
wds-link: no
bridge: yes
routeros-version: 6.32.2
last-ip: 192.168.250.164
current-tx-powers: 1Mbps:27(27/27),2Mbps:27(27/27),5.5Mbps:27(27/27),11Mbps:27(27/27),6Mbps:27(27/27),9Mbps:27(27/27),12Mbps:27(27/27),18Mbps:27(27/27),24Mbps:27(27/27),36Mbps:27(27/27),
----ess side
status: running-ap
channel: 907/5/g
noise-floor: -110dBm
registered-clients: 1
current-tx-powers: 1Mbps:27(27/27),2Mbps:27(27/27),5.5Mbps:27(27/27),11Mbps:27(27/27),6Mbps:27(27/27),9Mbps:27(27/27),12Mbps:27(27/27),18Mbps:27(27/27),24Mbps:27(27/27),36Mbps:27(27/27),48Mbps:25(25/25),54Mbps:24(24/24)
current-ofdm-errors: 1701
current-cck-errors: 1
notify-external-fdb: no
0 wlan1-gateway D4CA6D0D5AAB D4:CA:6D:0D:5A:AB no -69dBm 1.5Mbps 5m27s
With SNR and signal this good.. I figured the link would work well but it does not. I see a lot of OFDM errors and the CCQ is very bad.
/interface wireless> /tool bandwidth-test 192.168.235.10 duration=10s protocol=tcp
status: done testing
duration: 11s
rx-current: 570.1kbps
rx-10-second-average: 580.0kbps
rx-total-average: 580.0kbps
random-data: no
direction: receive
/interface wireless> /tool bandwidth-test 192.168.235.10 duration=10s protocol=tcp direction=transmit
status: disconnected
duration: 10s
tx-current: 0bps
tx-10-second-average: 0bps
tx-total-average: 0bps
random-data: no
direction: transmit
I can connect to the remote side but it will disconnect a lot and trying to use the internet is very difficult.
Here is a spectrum scan.
897 -90 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
897 -89 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
898 -94 ::::::::::::::::::::::::::::::::::::…
898 -91 :::::::::::::::::::::::::::::::::::::::::::::::::::::…
899 -92 :::::::::::::::::::::::::::::::::::::::::::::::…
899 -93 ::::::::::::::::::::::::::::::::::::::::::…
900 -95 ::::::::::::::::::::::::::::::…
900 -94 ::::::::::::::::::::::::::::::::::::…
901 -91 :::::::::::::::::::::::::::::::::::::::::::::::::::::…
902 -86 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
902 -77 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
903 -87 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
904 -78 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
904 -84 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
905 -87 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
905 -80 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
906 -87 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
907 -80 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
907 -83 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
908 -85 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
908 -79 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
909 -81 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
909 -78 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
910 -82 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
910 -81 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
911 -76 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
912 -73 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
912 -63 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
913 -74 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
913 -78 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
914 -78 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
914 -70 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
915 -66 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
915 -67 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
916 -66 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
917 -71 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
917 -76 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
918 -77 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
919 -82 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
919 -84 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
920 -85 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
920 -80 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
921 -80 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
922 -81 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
922 -80 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
923 -81 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
923 -82 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
924 -86 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
924 -85 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
925 -86 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
925 -81 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
926 -80 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::…
When I try to do spectrum scans… a lot of the time I get this after a few seconds.
oct/04/2015 19:50:43 system,error,critical router was rebooted without proper shutdown by watchdog timer
and
echo: system,error,critical router was rebooted without proper shutdown by watchdog timer
spectral-history
max: < -90 <= . < -80 <= + < -70 <= * < -60 <= #
897 899 901 903 905 907 910 912 914 916 918 920 922 925
I really don’t see why this should work this badly.
I am guessing three things.
  1. Bad co-channel noise (which does not appear to be the case from what I see)
  2. Bad adj-channel noise (which I don’t seem to see in the numbers either)
  3. Bad hardware on one or both sides.
I already changed the coax on both sides. I have one more radio I am going to swap with but I am not convinced that is the issue.
With the numbers I see, I thought that 802.11n protocols might work so I tried to force the radios to connect at one of the 802.11n modulations… it would not link.
Is there anything more I can do? Any ideas?
