900mhz WISP
Hello, i’m developing an wisp, i wonder could i have 900mhz for wisp because i heart that frequency isn’t good for big amount of data?
also witch is better for voip 2.4 or 5.8ghz
thanks
Make sure that 900MHz is not prohibited by your country regulations.
It does not matter, which band is better to use. There should not be any problems, when proper installation, configuration, etc. used.
thanks, but i have notice that the 900mhz band is better for rural connection?. but based on your experience witch band is better for rural 2.4 or 900mhz
thanks
900, hands down, as long as you aren’t too close to a 850MHz cell or pager system.
