Hi
When I upload the new mipsbe version I did reset configuration and reboot, since then is not available anywhere, winbox, telnet, netinstall, I tried to make reset, no success at all.
Can someone help me, there is any solution?
Hi
Are you keeping the reset button pressed for more than 30 seconds when waiting for it to appear on netinstall?
Yes, I already tried that with no success.
The LED906 is almost ON, I know in a normal 911 Lite is to be OFF without making connection to other radio.
Is some kind of LED information code?
