911 Lite5 & wireless bridge, Os 7.15 beta8
Iam new to the forum, most probably such subject have been already rolled numerous times but I would kindly ask for pointing me in right direction
in terms of researching the answer, i am relatively new to the subject and need just a bit orientation…
Ive been trying to establish wireless bridge with not-much-distant 5gHz neighbour’s wifi router but succeeded randomly, ie cant really fix and repeatable rule for my config/for device see subject/.
Assumed topology is: 20m distant 5GHz wifi router, Mikrotik911Rb wlan1 on my facade, eth1 cable to any of my home routers-to spread my local wifi, plus eth1 from such router to my laptop for temporary administration. Generally iam aware of license 3 limits, however-afaik it should still be possible. Found so many contradicting configurations on internet that i am really lost with it…
WHere/how should it be started/cleared to achieve predicted results..?
Btw another issue is to get online w/upgrade repo…
Thx in advance,
ZZ
