Schema and heights of points:
point1(800m)<===15km===>point2(2300m)<==93km==>point3(1300m)<==11km==>point4(1000m)
Config:
Point1:
PC: P4 Celeron 2.4Ghz, 256MB RAM, MiniPCI CM9, CF 512MB
MT 2.9.27
Antenna: 90cm parabolic dish, 5-6Ghz converter, 2m low loss coax feeder
Band=5Ghz-turbo,mode=ap-bridge,wds-mode=static,with nstreme, framer-policy=exact size
Point2:
PC: P4 Celeron 2.4Ghz, 256MB RAM, MiniPCI CM9, MiniPCI SR5, CF 512MB
MT 2.9.27
Antenna to point1(CM9): 90cm parabolic dish, 5-6Ghz converter, 2m low loss coax feeder
Antenna to point3(SR5): 1,4m parabolic dish, 5-6Ghz converter, 2m low loss coax feeder
To point1(CM9): Band=5Ghz-turbo, mode=station-wds, wds-mode=static, with nstreme, framer-policy=exact size
To point3(SR5): Band=5Ghz-turbo, mode=ap-bridge,wds-mode=static,with nstreme, framer-policy=exact size
Point3:
MT 2.9.27
Antenna to point4(CM9): 90cm parabolic dish, 5-6Ghz converter, 2m low loss coax feeder
Antenna to point2(SR5): 1,4m parabolic dish, 5-6Ghz converter, 2m low loss coax feeder
To point4(CM9): Band=5Ghz-turbo, mode=ap-bridge, wds-mode=static, with nstreme, framer-policy=exact size
To point2(SR5): Band=5Ghz-turbo, mode=station-wds,wds-mode=static,with nstreme, framer-policy=exact size
Point4:
MT 2.9.27
Band=5Ghz-turbo,mode=station-wds,wds-mode=static,with nstreme, framer-policy=exact size
All MT are configured as transparent bridges
I’m not posting frequencies deliberately, I’ll just say that we use the high 5,8 band for the long link.
Results:
Between point1 and 2: signal=-56, Bandwidth=40Mbps full duplex
Between point2 and 3: signal=-63, Bandwidth=30Mbps full duplex
Between point3 and 4: signal=-54, Bandwidth=40Mbps full duplex
Thank You again MikroTik-the best wireless router OS in the world
And regards to all
