941 hap lite 2nd
I configured a 941 radius for hap lite with hotpot with Socifi.
I have some questions:
I have had to forget to activate the wireless because I did not detect it, as I can access the router again ?.
If you can not access: how could do a hard reset?
I tried to restore factory data but holding the reset button five seconds does not work, nor with 10 seconds left, nor netinstall pressing it detects 15 seconds or more …
Right now it is not the way to access the router to try to reconfigure all the steps manual mikrotik … nor I can restore the factory settings.
That limitations have 941 users connected simultaneously played hap lite to work with radius and socifi?
What is the scope of coverage wifi signal?
thank you
