-95 signal on WDS?
What does this mean? I cant remember and you can only serach the forum for words longer than 1 character (apparently -95 is less than 1).
Ive seen this but cant remember the solution…everything seems to be fine (in logs, AP wants wds, Connection established.), except the non MT device i right next to the antenna shows -95 rssi..but wds established
EDIT: RESOLVED: ITS WHEN THE ACK TIMEOUTS DIFFER ON A MT AND A NON MT DEVICE.
tks
usually -95 shown if the link in idle state, please try send some trafic passtrough that wds.
correct, send some data to those MAC/IP address and it should change.
In v3.0 it will show that info right when the client connects.
