951Ui-2HnD not enabling 1000 Eth port?
Hi there all,
I have a 951Ui-2HnD directly connected to a Ubiquity AF5X microwave link and all is working fine. However, I do have an issue with the eth port which for some reason does not want to set to 1000Mb. I have done a series of troubleshooting connecting the computer directly to the ubiquity gives me 1gb no problems, I have checked auto-negociation parameters, I tried forcing 1000 full duplex on both device, also tried the same with my computer connected directly to the port with auto neg off, and 1000 Full Dup enable, but nothing get it working. I am just wondering is the RB able to work on 1Gb speed? What could be wrong? This is annoying as I have a 200Mb connection and only get 100mb out of it.
Any tips and suggestions would be so much appreciated please!
Regards,
951Ui ethernet ports are all 100Mbps.
Hi Pukkita,
Thanks for your response, you are saying the router does not support 1000Mb? Wow, thats a bummer… it does offer the option tho in the OS, wierd, but I guess, nothing I can do but change for something else…
cheers,
https://mikrotik.com/product/RB951G-2HnD Note that G in the name. This one go 1000Mbps
Features and options depend on the hardware being used…
