951Ui-2nD MetaRouter
Hi i have ,
951Ui-2nD
https://mikrotik.com/product/RB951Ui-2nD
and i can’t install a VM due to low storage capacity.
is there any solution to expand it or delete unused packages?
No, since this model has SPI flash, MetaRouter is not supported.
it supports the Metarouter but i don’t have enough space on local storage
ANY HELP?
There’s no help. You can either buy some other supported device with larger storage, or you’d need to have really small metarouter. The latter could be theoretically possible if you are assembler guru, but realistically, I don’t think there’s any chance to create anything useful like this.
It might be fun exercise to netboot metarouter from network, loading only small PXE client locally…
