Long story short, a bridge port was dynamically created, how do I remove the flag? I wish to have things, not dynamic.
How do I simply turn the port static, or not have the dynamic flag?
What do you mean by "a bridge port was dynamically create"?
Where are you seeing what you don't want to see?
[demo@MikroTik] > /interface/bridge/port print
Flags: I - INACTIVE; H - HW-OFFLOAD
Columns: INTERFACE, BRIDGE, HW, HORIZON, TRUSTED, FAST-LEAVE, BPDU-GUARD, EDGE, POINT-TO-POINT, PVID, FRAME-TYPES
# INTERFACE BRIDGE HW HORIZON TRUSTED FAST-LEAVE BPDU-GUARD EDGE POINT-TO-POINT PVID FRAME-TYPES
0 H ether2 bridge yes none no no no auto auto 200 admit-all
;;; defconf
1 H ether5 bridge yes none no no no auto auto 1 admit-all
;;; defconf
2 I sfp1 bridge yes none no no no auto auto 1 admit-all
[demo@MikroTik] > /interface/bridge/vlan print
Flags: D - DYNAMIC
Columns: BRIDGE, VLAN-IDS, CURRENT-TAGGED, CURRENT-UNTAGGED
# BRIDGE VLAN-IDS CURRENT-TAGGED CURRENT-UNTAGGED
0 bridge
;;; added by pvid
1 D bridge 1 bridge
ether5
;;; added by vlan on bridge
2 D bridge 199-200 bridge
210
999
;;; added by pvid
3 D bridge 200 ether2
[demo@MikroTik] >
Are you asking about the vlan configuration on a bridge-port?
Before going into details, we need to know what you mean, and why you think dynamic is bad and "static" is good.
I don’t think dynamic is “bad” I don’t like the heterogenity, and I like to know that it won’t change.This is the output from port print and shows the flag:
printFlags: D - DYNAMIC
Columns: INTERFACE, BRIDGE, HW, HORIZON, TRUSTED, FAST-LEAVE, PATH-COST, INTERNAL-PATH-COST, BPDU->
# INTERFACE BRIDGE HW HORIZON TRUSTED FAST-LEAVE PATH-COST IN BP EDGE POIN PVID
0 wlan2 MBR none no no 10 10 no auto auto 48
1 wlan1 MBR none no no 10 10 no auto auto 66
2 ether2 MBR yes none no no 10 10 no auto auto 69
3 ether1 MBR yes none no no 10 10 no auto auto 24
4 mwlan MBR none no no no auto auto 24
5 ether3 MBR yes none no no 10 10 no auto auto 24
6 ether4 MBR yes none no no 10 10 no auto auto 66
7 LAN MBR yes none no no 10 10 no auto auto 69
8 D ether5 MBR yes none no no 10 10 no auto auto 69
I have never seen that flag on the output of interface bridge port print.
So I went looking. I have never used the following feature.
Says
Interface lists in VLAN table
Starting from RouterOS version 7.17, you can use interface lists for the
taggedanduntaggedproperties in the bridge VLAN table. This change allows for more flexible VLAN assignment to ports by simply modifying the interface list members, rather than updating each bridge VLAN entry individually.
But if you do, the entries will show up as dynamic.
Excellent deduction, ether5 is part of the LAN group but is not in the bridge port list (but ether2 yes)
