Hello, a guess question ![]()
I have a network made of two switches
Core Router -->Switch+network -->Switch2+network
Network is the same in both cases, the second switch is just an extension to another building. The cable that connects the two switches is some 120 meters long.
What happens is that some time the second switch gets completely frozen, no communication. It does not happen often, very rarely. When it freezes the only way to bring it up is actually turn it off, disconnect all cables, turn it on with no cable on it, than start putting cables one after another. A simple restart of it doesn’t work.
Two days ago it happened to the first switch, same behavior and same solution. Strangely enough during this kind of freezes, I can see with winbox the mac address of the router but can not connect to it.
I can not work out what could possibly cause it, I presume some packet generated by some PC on the network that remains alive even if switch is turned off.
What do you think could possibly cause this?
