A mangle rule is exhausting me....
ether7: 192.168.1.1/24
/ip firewall mangle
chain=input action=mark-connection new-connection-mark=WAN2_conn passthrough=yes in-interface=ether7
chain=output action=mark-routing new-routing-mark=to_WAN2 passthrough=no connection-mark=WAN2_conn
dst-address=0.0.0.0/0 gateway=192.168.1.254 gateway-status=192.168.1.254 reachable via  ether7 distance=1 scope=30 target-scope=10 routing-mark=to_WAN2
dst-address=192.168.1.0/24 pref-src=192.168.1.1 gateway=ether7 gateway-status=ether7 reachable distance=0 scope=10
A pc 192.168.1.100 connected to a switch together with MT ether7 and gateway, cannot ping routerboard and vice-versa unless I disable the “output” mangle rule or remove routing-mark from default route.
Why is this ??
I ask because same configuration works on other systems…
Thank you
It seems a routing take place inside the same “connected” network…why ?
Sorry for this “up” …
I’m trying to solve this issue I have when managing routerboard from “WAN” side : locally. ethernet, not over internet with a NATted dsl router :
From few presentation abut pcc I usually adopt:
an accept rule to avoid marking for local traffic :
/ip firewall mangle add action=accept chain=prerouting disabled=no dst-address=192.168.1.0/24
When a connection is initiated from the internet through one of the ISPs we need to ensure that this connections is replied through the same ISP (from the same public IP)
We need to mark these connections, and then put them in the proper routing table.
/ip firewall mangle
PCC rules then follow…
Then I need a default route unmarked as well as a marked one :
dst-address=0.0.0.0/0 gateway=172.16.217.254 gateway-status=172.16.217.254 reachable via  ether7 distance=1 scope=30 target-scope=10
dst-address=0.0.0.0/0 gateway=172.16.217.254 gateway-status=172.16.217.254 reachable via  ether7 check-gateway=ping distance=1 scope=30 target-scope=10 routing-mark=to_WAN2
The problem is doing so I lose local connection from maintenance pc connected to wan side of routerboard
Any hint ?
Some more details about IP addresses could perhaps help. I mean, first there’s 192.168.1.0/24, now 172.16.217.?/? came from somewhere, …
I’d start with rules like this, to make sure that locally connected subnets will always be looked up in main routing table where they have routes:
/ip route rule
add action=lookup-only-in-table dst-address=<locally connected subnet> table=main
