I finally got my hands on a RB2011UAS-2HnD-IN. My first experience with Mikrotik.
I have everything working (home situation) as it should:
wifi
guest wifi
firewall rules
pptp
But I do have some questions:
The position of the antennas seems different then the one I see on the web. I have one antenna on the right and one in the middle, instead of one on the right and one on the left. Seems odd?
Web proxy: Is the RB2011 capable of running web proxy? When enabling, where does it save the cache? External HDD?
I upgraded to 6.7. However: there is a menu with firmware information. Clicking on “upgrade” doesn’t do anything…
Are there some necessary tweaks that i should do?
one antenna isn’t attached like it should. Open up the RB2011?
Plisken; are you the owner of wirelessinfo.be? Are you JP?
When yes: we mailed some time ago according wifi channels.
When no: never mind
While it doens’t seem to be hard to upgrade the firmware, something goes wrong…
When clicking on “upgrade” nothing seems to happen. Will give it a try later today.
