The model name is Acer Aspire, WiFi adapter is Qualcomm Atheros AR5BWB222. Cannot connect to any Mikrotik device but OK with any other router.
Accidentally I found out that if I disctonnect AC power, I can easily connect to the Mikrotik routers. Can I change some settings to be able to connect even when AC is on?
Yes! You won’t believe, but there’s a fact. It connects only when I disconnect power adapter, e. g. only when running on battery. Then I can reconnect power wire and it remains connected.
Can you open the MikroTik wireless “registration table” and check your signal? If you could do this from another PC, you could monitor if the signal changes, when you plug in the laptop power supply. Maybe it causes interference in the laptop
I can, but it happens even when the Mikrotik router is lying on the same table close to the notebook.
“Interference” at the moment when I plug it in or out? No, I’m not trying to connect at the same moment I connect AC cable.
It cannot connect when it is on AC power, only key exchange or something like that. I suppose that it can be because of different ACPI modes, due to how BIOS manages WiFi adapter modes. But it ONLY happens with ANY Mikrotik router. I tried short and long preambles both on the laptop and the router, various wireless ranges, nothing worked until I put the power cord off.
ok, very interesting. please enable the “wireless,debug” log (add new logging entry with the mentioned task) and see what the debug says when you try to connect.
I still believe this is some power issue that causes your laptop wifi card to malfunction (it draws more power when searching and connecting), but of course it could be something else.
That’s not true. I do understand that the laptop (or, more specifically, it’s WiFi adapter) is bad. But this appears to be only with Mikrotik routers. Why? There’s definitely a problem in between.
