Hi Friends,
I’m tryng to do a script for a faill over CAPsMAN.
I Have 3 possible CAPsMAN called 1, 2 and 3.
Ping CAPsMAN1 if it doesn’t respond, swithc to CAPsMAN2 and so on.
I cheched the script on Terminal (Cut-Past) and it works.
I copyed it into script, run Script but do not run. No error appear.
I read the guide, but don’t understand why,
I copy here the script.
Someone can help me?
I need to schedule this script every 30 seconds.
#Check CAPsMAN Priority
#CAPsMAN (1) - 192.168.1.10 - RB952_Living_Manager
#CAPsMAN (2) - 192.168.1.11 - RB952_Studio
#CAPsMAN (3) - 192.168.1.14 - RB952_Backup
:global vIPCAPsMAN1 192.168.1.10
:global vIPCAPsMAN2 192.168.1.11
:global vIPCAPsMAN3 192.168.1.14
:global NameCAPsMAN1 “RB952_Living”
:global NameCAPsMAN2 “RB952_Studio”
:global NameCAPsMAN3 “RB952_Backup”
:global NameID [/system identity get name]
#Se CAPsMAN1 risponde e mi trovo in uno degli altri CAPsMAN, allora spengo il CAPsMAN di dove mi trovo.
:log warning (" Run Script “)
:if ( [/ping $vIPCAPsMAN1 interval=1 count=10 size=28]>=5 ) do={
:if ($NameID=$NameCAPsMAN1) do={
:if [caps-man manager get enabled] do={:log warning ($NameID . " 1 - CAPsMAN Already ON”)} else={/caps-man manager set enabled=yes
:log warning ($NameID . " 1 - CAPsMAN - ON")}
} else={
/caps-man manager set enabled=no
:log warning (“Attivato CAPsMAN IP: " . $vIPCAPsMAN1 . " – " . $NameCAPsMAN1)
:log warning ($NameID . " 2 - CAPsMAN - OFF”)
} else={
#Se CAPsMAN2 risponde e mi trovo in uno degli altri CAPsMAN, allora spengo il CAPsMAN di dove mi trovo.
:if ( [/ping $vIPCAPsMAN2 interval=1 count=10 size=28]>=5 ) do={
:if ($NameID=$NameCAPsMAN2) do={
:if [caps-man manager get enabled] do={:log warning ($NameID . " 3 - CAPsMAN Already ON")} else={/caps-man manager set enabled=yes
:log warning ($NameID . " 3 - CAPsMAN - ON")}
} else={
:log warning (“Attivato CAPsMAN IP: " . $vIPCAPsMAN2 . " – " . $NameCAPsMAN2)
:log warning ($NameID . " 4 - CAPsMAN - OFF”)
} else={
#Se CAPsMAN3 risponde e mi trovo in uno degli altri CAPsMAN, allora spengo il CAPsMAN di dove mi trovo.
:if ( [/ping $vIPCAPsMAN3 interval=1 count=10 size=28]>=5 ) do={
:if ($NameID=$NameCAPsMAN3) do={
:if [caps-man manager get enabled] do={:log warning ($NameID . " 5 - CAPsMAN Already ON")} else={/caps-man manager set enabled=yes
:log warning ($NameID . " 5 - CAPsMAN - ON")}
} else={
:log warning (“Attivato CAPsMAN IP: " . $vIPCAPsMAN3 . " – " . $NameCAPsMAN3)}
:log warning ($NameID . " 6 - CAPsMAN - OFF”)
and this is the code…
/system scheduler
add interval=30s name=schedule1 on-event=SetCAPsManager policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon
start-date=jun/23/2021 start-time=00:00:00
/system script
add dont-require-permissions=no name=SetCAPsManager owner=admin policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=“#
Check CAPsMAN Priority\r
\n#CAPsMAN (1) - 192.168.1.10 - RB952_Living_Manager\r
\n#CAPsMAN (2) - 192.168.1.11 - RB952_Studio\r
\n#CAPsMAN (3) - 192.168.1.14 - RB952_Backup\r
\n:global vIPCAPsMAN1 192.168.1.10\r
\n:global vIPCAPsMAN2 192.168.1.11\r
\n:global vIPCAPsMAN3 192.168.1.14\r
\n:global NameCAPsMAN1 \93RB952_Living\94\r
\n:global NameCAPsMAN2 \93RB952_Studio\94\r
\n:global NameCAPsMAN3 \93RB952_Backup\94\r
\n:global NameID [/system identity get name]\r
\n\r
\n#Se CAPsMAN1 risponde e mi trovo in uno degli altri CAPsMAN, allora spen
go il CAPsMAN di dove mi trovo.\r
\n:log warning (" Run Script ")\r
\n:if ( [/ping $vIPCAPsMAN1 interval=1 count=10 size=28]>=5 ) do={\r
\n\t:if ($NameID=$NameCAPsMAN1) do={\r
\n\t:if [caps-man manager get enabled] do={:log warning ($NameID . " 1 -
_CAPsMAN Already ON")} else={/caps-man manager set enabled=yes\r
\n\t:log warning ($NameID . " 1 - CAPsMAN - ON")}\r
\n\t} else={\r
\n\t/caps-man manager set enabled=no\r
\n\t:log warning ("Attivato CAPsMAN IP: " . $vIPCAPsMAN1 . " \96 " .
$NameCAPsMAN1)\r
\n\t:log warning ($NameID . " 2 - CAPsMAN - OFF")\r
\n\t} \r
\n} else={\r
\n#Se CAPsMAN2 risponde e mi trovo in uno degli altri CAPsMAN, allora spen
\n:if ( [/ping $vIPCAPsMAN2 interval=1 count=10 size=28]>=5 ) do={\r
\n\t:if ($NameID=$NameCAPsMAN2) do={\r
\n\t:if [caps-man manager get enabled] do={:log warning ($NameID . " 3 -
\n\t:log warning ($NameID . " 3 - CAPsMAN - ON")}\r
\n\t} else={\r
\n\t:log warning ("Attivato CAPsMAN IP: " . $vIPCAPsMAN2 . " \96 " .
$NameCAPsMAN2)\r
\n\t:log warning ($NameID . " 4 - CAPsMAN - OFF")\r
\n\t} \r
\n} else={\r
\n#Se CAPsMAN3 risponde e mi trovo in uno degli altri CAPsMAN, allora spen
\n:if ( [/ping $vIPCAPsMAN3 interval=1 count=10 size=28]>=5 ) do={\r
\n\t:if ($NameID=$NameCAPsMAN3) do={\r
\n\t:if [caps-man manager get enabled] do={:log warning ($NameID . " 5 -
\n\t:log warning ($NameID . " 5 - CAPsMAN - ON")}\r
\n\t} else={\r
\n\t:log warning ("Attivato CAPsMAN IP: " . $vIPCAPsMAN3 . " \96 " .
$NameCAPsMAN3)}\r
\n\t:log warning ($NameID . " 6 - CAPsMAN - OFF")\r
\n}\r
\n}\r
\n}\r
\n”
