a question about connection-state in filter rules
Hi
I have a very general question and I searched the forum, I also read the WIKI but i didn’t find the straitforward answer.
In IP/Firewall/FilterRules, under “connection-state” section, what is the relationship between those states? it is “or” or “and”? in other word, it’s a “match all” or “match any”?
for example, these 2 lines are from default config:
7 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection connection-state=established,related
8 ;;; defconf: accept established,related, untracked
chain=forward action=accept connection-state=established,related,untracked
so, when do the action=fasttrack-connection will do it’s job? when a connection is established “and” related? or just one of them would be enough to take action?
thanks in advance
According to the comment in the rule following the link below we can see that: it has to be related and established.
https://wiki.mikrotik.com/wiki/Manual:IP/Fasttrack
as soon as I find more documentation post here
It’s “or” not “and”.
It would be nice if the documentation specified these things explicitly. I’m afraid it is full of these sort of gaping holes though.
A connection can’t have different states at the same time so it is match any.
The worrying thing is how supposed trainers don’t even know this stuff.
Bit of a basic requirement for a trainer I’d have thought.
The trainer focussed on the term fasttrack which was not the question. I have not a big problem with it and he was unsure about his answer as you can read.
Thanks all of you, leoservices & sid5632 & msatter
as you said, match any makes much more sense.
if there is no problem, I have another question about firewall and i ask it in this Topic.
as i read the “default config” rules in “ip/firewall/filter”, there is no mention of allowing new connections(for example from LAN interfaces to WAN interface)
so, a new connections passes through all of the > defconfig > rules and hits the end, then there is an implicit allow there. so this new connection will be allowed.
after that, if there was a reply and connection state become “established”, this connection will be catched by fasttrack rule in > defconfig > and the action that defined there will be taken.
is this statement true?
This is how I see it:
Between fields, i.e. src-address and dst-address is “and”, within the same filed, i.e. Port 80,442, 6060, etc. it is “or
