Hi everyone,
I have been working on a RADIUS system and its almost complete. Based on Freeradius.
Below are the features which are complete and are running in a production environment for an ISP of about 3000 customers.
Server Management
a. Add / Remove / Edit Mikrotik Routers from web interface
b. Check service status for related services (radius, http and mysql)
c. Check if any table in mysql database is crashed, if found crashed a repair button will show on web-interface. -
User Management
a. Add / Remove / Edit users from web-interface
b. Show online users (can kick / remove any online user from the list)
c. Show user statistics
d. Disable / Enable user
e. Change password -
Card Management
a. Scratch card generation based on profiles
b. Export card list in Excel and PDF format
c. Scratch cards can be assigned to any Dealer / Re-Seller as they are generated -
Support Management
a. Show all online users
b. Show online users for individual areas / group
c. Change user password
d. Can kill stale / hang sessions
f. View / Reply / Resolve support tickets -
Re-Seller Area
Re-Seller is the entity which can be given an area to manage, under which there can be dealers, sub-dealers or users
a. Re-Seller can add Dealer. While adding Dealers, Re-Seller has to assign profiles to Dealers with the amount at which they agree
b. Re-Seller will be assigned a number of cards which Re-Seller can assign to their Dealers.
c. Re-Seller has a billing section to generate monthly invoices for Dealers based on the rates which Dealer and Re-Sellers agreed
e. Re-Seller can generate a support tickets -
Dealer Area
Dear is the entity which will come under a Re-Seller or Admin. Dealer can has sub-dealers and users
a. Dealer can Add / Edit / Remove users
b. Dealer can Add / Edit / Remove Sub-Dealers
c. Dealer can perform User Management Tasks on their or their sub-dealers users
d. Dealer can kill stale / hang sessions for their or their sub-dealers users
e. Can Re-charge scratch cards on their or their sub-dealers users
f. Can generate support related tickets -
Sub-Dealer Area
Sub-Dealer is the entity which comes under Dealer and can only has Users.
a. Can perform User Management Tasks only on their own users
b. Can Re-charge scratch cards only on their own users
c. Can generate support related tickets -
User Area
a. Can check their own statistics
b. Can change passwords
c. Can re-charge their own accounts
d. Can generate support related tickets -
Billing Area
This belongs to accounts section. When adding Dealer or Re-Seller, admin specifies the rate on which they agree.
Based on those rates billing is performed.
a. Generate invoice for Dealers or Re-Sellers on monthly basis
b. Invoice contains details list of scratch cards provided by admin to respective entity with date and serial numbers
c. Payments can be made anytime
d. When making payment, one can either specify particular invoice to clear from or from the total amount -
Admin Area
a. Server Management
b. Card Management
c. Support Management
d. Global Settings
There are some cronjobs running on system which are checking
→ Stale sessions
→ Daily user sessions
→ Scratch cards expired on daily basis
Customized script to check simultaneous session in multi-router environment using SNMP.
Currently this system has only been tested with PPP section and not with HotSpot. Once everything is 100% complete, I will add HotSpot section.
I will be attaching screenshots very soon.
Feedback from you guys will be appreciated.
