a scheduler problem !!!!
Dear friends …
i made a script which chick users traffic limit , the script work fine in new terminal ,
but didn’t work if a put it in a script and name this script as “check” if i press run script , it dose not work ,
if I call this from a scheduler also , dose not work ,
but if i copy this script and past it in new terminal it works fine !!!
I need run this script each 5 mints ,
any help !!! :confused:
My guess is its a permission problem… make sure you set the appropriate permissions on the script and the scheduler.
if you mean with “permission” the policy … all policies is checked !!! in both of scheduler and script !!!
the problem solved by itself , i don’t know why it happened , and how it solved !!!
anyway , all i did , backup , restore the same file , everything became normal :slight_smile: :laughing: :laughing:
