A simple basic question , help
hello..
i just bought a new device from Mikrotik .
i want to ask something…
I bought the device to separate the playstation from laptops and mobiles.
how can i make my playstation run without being affected by other devices , or make my playstation when i open it , it takes half my network speed alone (Anything like that )
What i do , or search on what ?
Thanks :slight_smile:
If you want to isolate the Playstation from other devices in your network, create a new network just for the Playstation and add firewall rules to prevent the networks from seeing each other. If your concern is more about bandwidth usage than security, then you need to use queues to manage bandwidth.
