A simple router with rules
Dear Amigos ,
how simply can i configure a routerboard 433 with no wireless needed to be act like a simple router ADSL WAN on eth1 and Lan for eth2 and eth3 , so i can add rules for bandwidth + close some ports like 80 if i need my users only use msn , and how to do content or url filters. can i create groups?
thanks
Don’t buy a wireless mini-pci card for the RB433 and you won’t have a wireless interface to configure. :smiley:
You will plug the DSL modem from the ISP into ether1 (if you are using PoE then you will pass through the injector). Then you will want to read about PPP Interfaces in the MikroTik doc:
http://www.mikrotik.com/testdocs/ros/2.9/interface/ppp.php
The PPP Client section is what you will need to configure to allow your RB433 to make a PPPoE connection with your ISP through your DSL modem.
Read about configuring ethernet interfaces and addresses here:
http://www.mikrotik.com/testdocs/ros/2.9/interface/ethernet.php
http://www.mikrotik.com/testdocs/ros/2.9/ip/address.php
Read about setting up Masquerading so your devices can access the internet through ether1 using one internet IP address, here:
http://www.mikrotik.com/testdocs/ros/2.9/guide/basic.php
Actually, read that whole section as it is very helpful for a beginner.
Web proxy feature.
http://www.mikrotik.com/testdocs/ros/2.9/ip/proxy.php
