A VPN question.
Hello everybody.
I use to connect to internet via VPN, so I have IP and Subnet mask, and host IP address. I use an old Pentium with 2 NICs. So I guess I must set NIC1 with this IP and subnet. Also I make a connection between a laptop and the router via cable. But I do not understand how to set the VPN on the router. I need the router to connect to internet via VPN, and the client computers to connect to internet through it.
How do you connect to the Internet via VPN?
what kind of VPN is it, please give more details on what you want to configure …
To set up the connection in Windows: IP 10.10.20.65; Subnet 255.0.0.0; After I create a VPN and put a server address 10.10.20.1. So I need the Microtik to connect to internet with these settings and to route this connection to two computers, and later may be more with a switch. Tonight I will try again to set it up.
example:
[admin@PPTP-Client] interface pptp-client> add user=jack password=pass connect-to=10.5.8.104 disabled=no
more info: http://www.mikrotik.com/testdocs/ros/2.9/interface/pptp.php
