A52 hpn boot loop.
Hello to all network addicts.
Before i start i would like to say that i did a research over the internet but nothing seemed to help. So i decided to ask you guys for sharing some knowledge.
I bought a Mikrotik A52hpn. It was working flawlessly for a week but then i decided to install some packages on it. Downloaded them from mt.lv and started copying those i wanted to have. Well i copied a few and then i decided to reboot the device. A millisecond before the initiation of the reboot command i saw that routerboard memory is almost full. Since that reboot i cannot start the device. It just keeps rebooting every 5 seconds. I cannot see it through in Winbox either.
Checking the internet i saw suggestions about trying with Netinstall but no luck at all.
Please advice me what to do next, Can i connect somehow to the device and flash it’s memory?
Regards,
Stefan
