about 450g
Can any body help me in configuring 450G
I Have 2 different ISPs Connectivity in my lan i have taken bandwidth for one of this isp .i want change my connections from one bandwidth to another. so for that i am using 450Gh as server
I have problem with 450G i am using queues for bandwidth management and i have problem with some customers that the gateway of my 450g doesn’t ping to that customers and when i keep another Isp ips that gateway comes it is coming .it is working properly . but when ever i configured this ips this is not working properly some of my connections are not having any problem with but some have problem with ping the ping is not coming properly when ever i will repair lan of that customer which is having problem the ping come after that the ping is not coming pls help me in that
thanks in advance sorry for my poor English .
Sorry, rely cant understand, looks like you can ping customer after you refresh there ip but after a bit of time, you cant ping them? From where to where do you ping. What load balancing do you use?
Could be something with your routes? Do trace from client to server.
Mabe your load balancing, have a look at PCC load balancing.
