About Android Strongswan "Got:critical error: AUTHENICATION_FAILED"
Hello guys
I encountered some problems during the use of the routers. When I used the IKEV2 authentication mode as the eap radius, the Android phone client strongswan 1.9.4 could not connect.
But if you use ras signature authentication method is no problem, this is a bug? My system version is 6.42.1
Hey j0o3,
can you send me more details about your configuration? trying to setup strongswan with mikrotik and having son success…
I always get (no_proposal_chosen notify error)
maybe you shoud try use diffrent encrypt method,or mssing some encrypt method in the “ip–ipsec–Proposals” or See wiki help
https://wiki.mikrotik.com/wiki/Manual:IP/IPsec#Android_Client_Notes_2
Hey j0o3,
I have the same problem.
v6.42.6 (Current)
Got:critical error: AUTHENICATION_FAILED.
Did you get a solution to this?
