About "Dst. Limit"
Firewall rule->extra-> Dst. Limit have many options
Such as Rate ; Burst; Limit By ; Expire
Limit By have four choices
1、dst. address
2、dst. address and port
3、src. and dst. addresses
4、addresses and dst. port
What’s means of these choices?
How to use these choices?
I have read the manual many times, but not find information about these.
Please tell me , thanks very much.
dst-limit is similar to ‘Limit’, dst-limit provides more options to divide/limit traffic.
Limit-by value defines the clasifier/matcher, that will be used for packets.
Accordingly you have four choises to select (dst-address, packets dst-address will be used as classifier, etc.).
Thanks for reply.
Can you tell me how to use “src. and dst. addresses” and what means of it?
I really need it , thanks again!
up up up
Up for answer…
SmartBoy,
There are definitions and the differences between src and dst nat @ http://www.mikrotik.com/testdocs/ros/2.9/ip/nat.php
Matt
