hi every one
if you hide the ssid of any mikrotik access point …ok..
make a scan by any mikrotik device of the wireless networks ,you find out that hidden ssid can be seen by that mikrotik device!!!
what is the wrong !!!
hi every one
The only way to make your radio undetectable are: disable wlan1
Hide SSID is only to not show SSID on normal operations on SmartPhones and Computers.
unlogic replay…if you disable the wlan1= shutt down the access point !!!
im talking about 5.8 ghz transmitting .i have omini antenna + rb433+sr5
i hide my ssid .but in fact .the ssid had not been hidden!!!
something is tooooooooooooooooooooo strange…
Read again: I reply EXACTLY at your question:
The only way to make your radio undetectable are: disable wlan (1)
