about L2MTU
I have two routers:
  • physical RB1100AHx2 RouterOS 6.35.4
  • virtual CHR RouterOS 6.37.1
  1. On both routers I see at least two interfaces (RB1100AHx2 has more, but lets ignore those for now):
    RB11000AHx2
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 0  RS ether1bond                          ether            1500  1598       9498 12:34:56:78:90:18
 1  RS ether2bond                          ether            1500  1598       9498 12:34:56:78:90:19
CHR
 0  RS ether1bond                          ether            1500                  12:34:56:78:90:77
 1  RS ether2bond                          ether            1500                  12:34:56:78:90:79
Question: Why is L2MTU only visible on the RB1100AHx2? Physical capability or driver capability?
  1. I created bonded interfaces using 802.3ad:
    RB11000AHx2
 2  R  bond                                bond             1500                  12:34:56:78:90:18
CHR
 2  R  bond                                bond             1500  1500            12:34:56:78:90:77
Question: Why is L2MTU only visible on the bonded interface on the CHR?
Put same version on both devices, there must be some change in changelog that does that.
Thanks for your response, I found it.
Version 6.36:
*) bonding - implemented l2mtu value == smallest slave interfaces l2mtu;
Since L2MTU isn’t available on the CHR interfaces, why is L2MTU set on the bonded interfaces?
In cases when L2MTU is not supported by the driver L2MTU=MTU, that is why you see 1500 for bonding interface.
