about mikrotik RouterOS and RouterBoard??
I’m newbie for mikrotik.. i need your help..
when i’m read the description of the other AP (not mikrotik AP) the AP only can hold 15 user when online together, and when i read FAQ about mikrotik (at mikrotik.co.id) it can hold until 100 client.. i want to ask. that can hold until 100 client is RouterOS or RouterBoard??
sorry if my english bad. :smiley:
Best Regards,
Your friend
I’ve got more then 15 people on a single AP (running NStream) and the load is fine. I think I should easily be able to put 40 or more in the AP. of course this is depending on how much traffic your customers push…
even if you use RouterOS on a PC based router (not routerboard), you will still be able to connect more than 30 clients. This depends on the RouterOS and the antenna and wireless card.
I used Linksys WRT54GL, and the plan the client will more than 50. What should i do?? the antenna i used is Omni Slotted Waveguide 15-18 dbi.
Best Regards,
Your friend
this is a forum about RouterOS …
