There will be any improvements or bugs fix on OSPF routing protocol?
+1
It is very important question!
+1
We want to roll out like 80 cloudcore routers in our DC but with the current state of OSPF we will be getting too many issues we feel.
What ospf issues are you having?
Sudden master flags wrong and the ospf recalculates many times before stabilizing and sometime triggering a crash on one of the OSPF routers.
100% Mikrotik OSPF network with some IPv4 BGP.
There are some threads on this which MT has been very absent on.
We have made some investigation into the issue now, and it seems it has to do with when the links change.
Like switching port and moving the ip along, the system crashing and booting, etc.
So im guessing there is a small issue somewhere in the internal code making the LSAs wrong in these conditions.
Has anyone tried v6? Those routing crashes should be fixed.
No, it shoud not be fixed!
Are NSSA areas fixed in v6?
Not possible. due to the crash in vrf.
What kind of crash in VRF? Is it reported to support?
At all system/boards I have tried with 6.rcXX, the enabling of MPLS-BGP is ok, but at once as a VRF is created, the system stop responding to commands.
Its not even possible to do a supout.rif file.
http://forum.mikrotik.com/t/v6-rc6-released/62201/1
I was told by normis that the bug was known.
