About Queueing a new IP Pool Addresses
Hello Mikrotikians ,
how are you all
past, i have one ip address pool it is 10.0.0.2-10.0.0.254
so all the 255 ip addresses are finished
so lan interface can't offer new ip addresses
due to this i've entered the ip pool again and edited the pool to 10.0.0.2-10.0.1.254
and added it to ip addresses and DHCP Networks
After Test
i've got a new range 10.0.1.1-10.0.1.254
a new pc connected to the network and got 10.0.5.1 but here is the problem i've queued this ip address to limit the target download and target upload at 64k/64k but queue failed to limit the transfer rate and it stills 200 kbps direct link download (IDM) even though the regular old ip addresses 10.0.0.1-10.0.0.254 (Queues is great and do it's job)
so what is the solve for this problem :frowning: :frowning:
Mikrotik Version 2.9.27
thx in advance :slight_smile:
After Test
i’ve got a new range 10.0.1.1-10.0.1.254
Does not seem as though new pc ip is from pool?
and. after fixing that issue. Maybe consider upgrading os? :stuck_out_tongue:
sorry it was 10.0.1.5
mistyping :frowning:
