about queues
version:router os 3.20.
cpu:intel E1200 .
load : 20% max
15% avg
client pc :100 clients.
Under these conditions ,only a part of client pc queues on the winbox…
why? cpu is the bottleneck?
i hope someone can help me …thank u…
O_o
maybe a screenshot?.. I don’t understant what you mean…
just like this…
  1. What’s the problem?
  2. Why do you need so many simple queues. Search wiki for PCQ.
i want to know all client queues…but in my winbox just display a part of client queues
how do you know that you have more :slight_smile: ?
when i download a file from internet, my queues is blank in winbox .
Do you mean the “RX Average rate” column? It doesn’t show rate when you download something? Check what Queue Type you have for those queues. Set it to “default”
yes,It doesn’t show rate when i download something…
test again
:frowning: :frowning: :frowning: :frowning: :frowning:
You are downloading from the wrong IP, you can see that the download speed doesn’t match the limitation.
version of RouterOS?
3.20
upgrade to v4.3 and see if it works then. also - as I said, your screenshot shows that you are testing from the wrong IP, because your download speed is not limited !!
wrong ip???
i can not understantd what your mean…
the pc you useforthe test have the ip 192.168.6.6 ?
Well, apparently your queue is configured wrong, because the Queue is simply not working, that’s why it doesn’t show any speed - no traffic is matching the queue!
yesterday ,i maked a mistake ,the ip is wrong.
but i do the test again today.
the bug still alive.
