hi every one
i have rb 433…i make it as a wonderful router .it very perfect router …actually ..i used my rb433 for (just) a pppoe server no more no less
the question is/ which packages in the image down must be founded for my case (really i need for my case ) and which packeges i can delet that nothing happens to my rb433 that still works normally as pppoe server…with thanks
only “system” is required. if you can’t identify any other features that you will use (by name), you can just ignore them. for pppoe you will also need ppp.
you can read here about packages: http://wiki.mikrotik.com/wiki/Manual:System/Packages
thank you very very much normis…do you mean i must have just the 2 packages as shown down!!!
depends on what you will use. maybe you need DHCP to get IP address from the ISP. maybe you need ntp to get date and time. Maybe you need Security to get SSH access to your device. If not, then yes, 2 packages will be enough
nice
[imghttps://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcRSuUULgnqbtAkfhWLjDMNKFhUfMCrKBc9Y7dIYfgtzapcNQCPa[/img]
nice …
another question please with my high appreciation …
i want to remove the fellowing optoins down…ho to do that ??
You cannot remove menu items from Winbox.
