I have purchase RB5009 which is working well since from last 2 years
yesterday night I just update it from 7.19 to 7.20 Stable version ARM64 but right now it's showing “maximum number of connection is exceeded license limite 500”
and the user still online under 300 and I also set maximum limit 2000 from pppoe server
but the users still under 300 I also try to downgrade it but it will not downgrade
A useless waste of time that has nothing to do with this. allowed-versions: 7.13+,6.49.8+
You haven't explained at all how you're trying to downgrade.
If you want to downgrade manually, in addition to copy the main package for the correct processor,
you must also copy the other additional packages already installed, otherwise it won't let you downgrade.
After restarting on the downgrade attempt, what does the log say about it?
If not work, use netinstall and after reboot reload the latest backup.
Because... you made a backup, right?
A tip for next time:
Try on another spare identical device first.
Visit the forum BEFORE upgrading... (dozen of reported problems with pppoe on 7.20+) If it works, don't fix it...
