About Wifi roaming settings in CAPsMAN
I want you to tell me if you know someone I do not know how to set.
In a CAPsMAN the current CRS, I have created an environment that is connected to three CAP,
but I do not know how to set Wifi roaming in CAPsMAN control.
It’s thought to be or may be set to Mesh at first, but you are also using the CAPsMAN,
datapath can only specify a bridge.
Is there a way to roam in some other way?
PS
Because English is not good, I am using Google.
As for now you can use a bridge in datapath configuration.
It will roam ok between APs’. Also you may want to setup access list for dropping low-signal clients (for them to reconnect to strongest AP).
Roaming will not be seamless but at least it’s working.
Thank you for answer.
It is that if I bridge to configure the datapath, it is roaming.
It’s not a seamless Unfortunately, I wonder would not be helped it’s current status.
But I was very helpful.
I know you’ll do the same for someone else :wink:
As for seamless roaming we should wait for devs from Mikrotik.
At least as I saw on the forums they like this idea but for now there is no more info on topic.
Happy hacking! :slight_smile:
