About wireless band mode 2GHz-2M
we need change the wireless band mode to 2GHz-2M, I thank only change the ROS,not the hardware.Since it is important for us to use this mode in a government project.
thanks
What do you mean by 2GHz-2M ?
RouterOS supports bands,
2.4ghz-b 2.4ghz-g-turbo 2ghz-10mhz 2ghz-5mhz 5ghz-10mhz 5ghz-5mhz
2.4ghz-b/g 2.4ghz-onlyg 2ghz-11n 5ghz 5ghz-11n 5ghz-turbo
These bands are provided with the latest version.
Some of them could be unavailable for you due to country regulations. Set band on both ends. then it should work fine.
2ghz-11n 5ghz-11n ???
Well, it is widely known that MikroTik is working on 802.11n support.
I am sorry, I do not have a clear description of 2GHz-2M , I asked the 2GHz-2mhz
Do you mean is 3.11 will support the 11n
