Today in the moning during 1 hour was updated ~200 RB.
But 6 RB has problem:
3 don’t start;
3 start with only few packages (other is absent, not disabled). Mainly system, user-manager;
I don’t need help but I say it for information.
3 don’t start;
Console log on broken RB.
Any suggestions?
System repaired with Netinstall.
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Starting…
modprobe: module flash not found.
modprobe: failed to load module flash
modprobe: module logring not found.
modprobe: failed to load module logring
/etc/rc.d/run.d/S02logring: 10: cannot create /dev/log241: No such device or ads
/etc/rc.d/run.d/S02panic: 2: cannot create /dev/log241: No such device or addres
Jan 1 00:00:04 localhost syslog.info syslogd started: BusyBox v1.00 (2013.04.2)
/etc/rc.d/run.d/S05syslog: 4: cannot create /dev/log240: No such device or addrs
/etc/rc.d/run.d/S06mipsdog: 2: cannot create /dev/log241: No such device or adds
modprobe: module log not found.
modprobe: module snif not found.
modprobe: failed to load module snif
modprobe: module btest not found.
modprobe: failed to load module btest
modprobe: module ticker not found.
modprobe: failed to load module ticker
/etc/rc.d/run.d/S07rb: 3: cannot create /dev/log241: No such device or address
/etc/rc.d/run.d/S08softdog: 3: cannot create /dev/log241: No such device or adds
/etc/rc.d/run.d/S08voltage: 2: cannot create /dev/log241: No such device or adds
Starting services…
/etc/rc.d/run.d/S10nova: 6: cannot create /dev/log1: No such device or address
Fatal error 0x853
Please contact support@mikrotik.com
connect failed (errno=2)
Shutting down…
Stopping services…
Jan 1 00:00:07 localhost syslog.info System log daemon exiting.
/etc/rc.d/run.d/C95panic: 2: cannot create /dev/log241: No such device or addres
System halted.
