Absolutely no connection
I recently bought a RB3011 and have the following problem:
the manual says, I should connect my PC to ports 2 - 10 and then try to connect to 192.168.88.1 for configuration. But this does not work. I have set my IP adress to the same network and entered the correct gateway and everything else but nothing seems to help.
I also tried to connect via Winbox by entering the MAC adress of the ethernet port. But I cant get a connection there too. It seems like the RB just dont want to be configured. I already resetted the board. Netinstall isn’t working, too, btw. It just does not show up in the devices list.
Does someone here have an idea how to solve this?
Kind regards
Ben
