abuot rb411h or rb433 configuration
hello everybody
i have some question:
(1)can i enable nstreme on rb411ah or rb433 routerboard configured as access point
(2) what is anteena gain and what it should be ?
(3)what is ack time out on the wlan interface advance page?
(4)what is tx power mode what is good card rate or all rate fixed
kindly help???
with best regard
from suraj
Dear, sorry for my bad English but i true to help you.
Antenna gain: Enter your antenna strength, for example 10DB
Tx Power = radiated power of your radio without antenna card.
= Rate for me, this set i always automatically
Ack-Timing: Enter the distance between two stations.
N-stream i don’t know
I hope to help you
Greetings
