AC Lite under CapsMan control. No internet on LAN port
Hi all,
I have MikroTik RB952Ui-5ac2nD as router (CAPsMan) and Mikrotik wsAP AC Lite as access point (CAP).
Wifi works just fine, but LAN ports on AP AC Lite do not provide internet via ethernet cable.
They all are in bridge but this does not help...
Any ideas on how can I make this setup working... ?
============AP Lite config===========
jun/14/1970 05:22:14 by RouterOS 6.47
software id = WBDM-4RE6
model = RBwsAP-5Hac2nD
serial number = B8820B24B5BC
add name=bridge1
/interface wireless
managed by CAPsMAN
channel: 2412/20-Ce/gn(18dBm), SSID: machina2, CAPsMAN forwarding
set [ find default-name=wlan1 ] ssid=MikroTik
managed by CAPsMAN
channel: 5180/20-Ceee/ac(14dBm), SSID: machina5, CAPsMAN forwarding
set [ find default-name=wlan2 ] ssid=MikroTik
/ip hotspot profile
add bridge=bridge1 interface=wlan1
add bridge=bridge1 interface=wlan2
/interface wireless cap
set discovery-interfaces=ether1 enabled=yes interfaces=wlan1,wlan2
/system identity
set name=AP2
===========ROUTER config=============
jan/03/2021 17:14:00 by RouterOS 6.47
software id = 3BYN-IVVH
model = RB952Ui-5ac2nD
serial number = BEB80B38016B
/caps-man channel
add band=2ghz-b/g/n frequency=2412 name=channel2 tx-power=20
add band=5ghz-a/n/ac frequency=5180 name=channel5 tx-power=20
add admin-mac=C4:AD:34:59:80:54 auto-mac=no comment=defconf name=bridge
add name="bridge1- guest"
set [ find default-name=ether1 ] mac-address=E8:94:F6:B8:41:B9
/interface wireless
managed by CAPsMAN
channel: 2412/20-Ce/gn(20dBm), SSID: machina2, CAPsMAN forwarding
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n channel-width=
20/40mhz-XX country=no_country_set distance=indoors frequency=auto
frequency-mode=manual-txpower installation=indoor mode=ap-bridge ssid=
machina2 wireless-protocol=802.11
managed by CAPsMAN
channel: 5180/20-Ceee/ac(17dBm), SSID: machina5, CAPsMAN forwarding
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-a/n/ac
channel-width=20/40/80mhz-XXXX country=no_country_set distance=indoors
frequency=auto frequency-mode=manual-txpower installation=indoor mode=
ap-bridge ssid=machina5 wireless-protocol=802.11
/caps-man datapath
add bridge=bridge client-to-client-forwarding=yes name=datapath1
add bridge="bridge1- guest" name=datapath2-guest
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm
name=security1
add name=security2-guest
/caps-man configuration
add channel=channel2 datapath=datapath1 mode=ap name=cfg2 rx-chains=0,1,2
security=security1 ssid=machina2 tx-chains=0,1,2
add channel=channel5 datapath=datapath1 mode=ap name=cfg5 security=security1
ssid=machina5
add channel=channel2 datapath=datapath2-guest mode=ap name=cfg2-guest
rx-chains=0,1,2,3 security=security2-guest ssid=guest2 tx-chains=0,1,2,3
add channel=channel5 datapath=datapath2-guest mode=ap name=cfg5-guest
rx-chains=0,1,2,3 security=security2-guest security.authentication-types=
"" ssid=guest5 tx-chains=0,1,2,3
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=
dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp_pool1 disabled=no interface="bridge1- guest" name=dhcp1
/queue type
add kind=pcq name=queue1-guest-download pcq-classifier=dst-address
pcq-dst-address6-mask=64 pcq-rate=5M pcq-src-address6-mask=64
add kind=pcq name=queue2-guest-upload pcq-classifier=src-address
/queue simple
add max-limit=5M/5M name=queue1-guest queue=
queue2-guest-upload/queue1-guest-download target=192.168.10.0/24
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas
sword,web,sniff,sensitive,api,romon,dude,tikapp"
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=
cfg2 slave-configurations=cfg2-guest
add action=create-dynamic-enabled master-configuration=cfg5
slave-configurations=cfg5-guest
add bridge=bridge comment=defconf interface=wlan2
/interface detect-internet
set detect-interface-list=all
set discovery-interfaces=bridge enabled=yes interfaces=wlan1,wlan2
add address=192.168.88.1/24 comment=defconf interface=ether2 network=
192.168.88.0
add address=192.168.10.1/24 interface="bridge1- guest" network=192.168.10.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.1.0/24 gateway=192.168.1.1
add address=192.168.10.0/24 gateway=192.168.10.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan type=A
add action=accept chain=input comment=UnblockCapsman dst-address-type=local
src-address-type=local
"defconf: accept established,related,untracked" connection-state=
established,related,untracked dst-address-type=local dst-limit=
1,5,dst-address/1m40s src-address-type=local
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=accept chain=input dst-address-type=local src-address-type=local
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
connection-state=established,related src-address=192.168.88.0/24
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment="defconf: masquerade"
/ip route rule
add action=drop dst-address=192.168.10.0/24 src-address=192.168.88.0/24
add action=drop dst-address=192.168.88.0/24 src-address=192.168.10.0/24
/system clock
set time-zone-name=Europe/Kiev
/system identity
set name=ROUTER
/tool mac-server
/tool mac-server mac-winbox
Anyone, any ideas ?
