AC network problem
Hi, All!
Recently I replaced my old RB with a new hAP AC Lite, because I want to use ac network. My Laptop desn’t have ac lan adapter, therefore I installed TP-Link Archer T1u adapter: http://www.tp-link.com/en/products/details/Archer-T1U.html .
When I installed drivers adapter appear in Windows 7 Device Manager. When I scan for networks , network from RB is available, and ask for password, but when enter correct password, wWindows tell me: Windows was unable to connect to “My 5G network”.
It is my RB wireless config:
I try with Windows 10 system and the result is the same.
Can someone tell me is the problem in Wireless configuration or in TP-link adapter
Thank You
P.S. I changed Band, Channel and Frequency in multiple configurations , but doesn’t have success
I tried with open (without password) network, but it was the same result
And the log what is telling you?
use wireless protocol 802.11
Does it work with the normal (internal) adapter?
Windows tends to sweep all problems under a simple “unable to connect” message, no matter if the
problem is in physical link, authentication or even something like DHCP or internet reachability.
So it may be that your wireless is actually OK but you have no DHCP server configured.
The RB log say nothing when I try to connect. Doesn’t have success and when changed to 802.11
I have configured Bridge which include eth2, wlan1 (2,4Ghz) and wlan2 (5GHz). The DHCP server is configured on this bridge
When I connect to wlan1 (2,4GHz) or with wire to eth2 there is no problem.
I do not have internal adapter, therefore buy USB TP-Link adapter to try ac network
Try with your phone? Most modern iphone/android variants have 5.8Ghz and AC - might be an issue with the drivers on the TP-link.
