Last night I tried to change the local IP address from 192 168 88 1 to 192 168 1 using WinBox with windows10. After that, I rebooted the router. As I understand it, an error occurred. After which I cannot reset the settings to factory settings, also everything that the official MikroTik representative advises does not work in my case. What am I doing wrong?
That’s not a valid local IP address, so WinBox wouldn’t have saved it. When you launch WinBox, is the router listed in the “neighbors” tab (connect via MAC address)? There is more than one way to achieve this, but the bridge address and the DHCP pool need to match logically so that new devices can connect to the new range.
Gateway address: 192.168.1.1
DHCP pool range: 192.168.1.10-192.168.1.254
The reset button is finicky on the ac2 (be careful not to press too hard), but you should be able to reset the device back to defaults easily.
